unconfigure bootprelay include-secondary
unconfigure bootprelay {ipv4 | ipv6} {vlan} vlan_name include-secondary
Description
Removes the specified smart relay configuration that was specified at the VLAN level.
Syntax Description
ipv4 Specifies unconfiguring the DHCPv4 BOOTP Relay service (default).
ipv6 Specifies unconfiguring the DHCPv6 BOOTP Relay service.
vlan Unconfigures BOOTP relay for a specified VLAN.
vlan_name Specifies the VLAN name.
include-secondary Removes the include-secondary configuration for the specified VLAN.
Default
IPv4 is the default relay service.
Usage Guidelines
Use this command to remove the specified smart relay configuration that was specified at the VLAN level.
The following command removes DHCPv4 BOOTP Relay service, and removes the include-secondary configuration for the VLAN "vlan 100":
unconfigure bootprelay ipv4 vlan  vlan_100 include-secondary
This command was first available in ExtremeXOS 15.4.
Platform Availability
